Aqueous Cleaner or Non Flammable Solvent to Flush Fuel from Metal Box Prior to Soldering
I'm looking for an aqueous cleaner or non-flammable solvent that can be used to flush out any fuel in a small metal box component before the wires of a new pump are soldered to the circuit.
Raymond Paulson
If it is an authorized repair on an aircraft, there is a published repair SOP or method to do it.
Navarre, Florida
