Thread 400/55
Brass plating on hinges
We are manufacturers of steel piano hinges and curtain pipes which are up to 12 feet long we want to do brass plating on it. Kindly inform us the most economical way of doing instead of doing nickel first and then doing brass or to apply copper first and then doing brass plating Or finishing the hinges first and applying directly brass on it to get optimum finish and which is as per European standards also.
ASHUTOSH2006
publicly reply to ASHUTOSH
If you are looking for a dull, matte look, then plating brass directly on the steel hinges is fine. But if you want a bright look, plating first with nickel (or white bronze) and then with brass is the "standard" approach and probably the most economical because brass does not "level" enough to be brightly reflective directly on unbuffed steel.
An alternative would be nickel plating followed by a brass tinted electrophoretic lacquer, and this would eliminate the need for cyanide in the process. This has been done on a lot of "brass" lamps, but I don't personally know whether it will work with hinges; electrophoretic lacquer coatings are very thin, so there may be no bridging between moving parts but I don't know for sure.
publicly reply to Ted Mooney
THANKS FOR YOUR INFORMATION REGARDING BRASS PLATING. CAN I GET THE SAME YELLOW FINISH BY ZINC YELLOW PASSIVATION. AS THIS IS MOST ECONOMICAL.
ASHUTOSH2006
They certainly can be zinc plated and yellow chromated, and a person who is not sophisticated in metal finishing may not object; but even the best yellow chromate doesn't really look much like brass to someone who is looking for luster. letter 4206 addressed this same issue.
One issue I have as operator of this site is that in trying to help the thousands of homeowners and consumers who submit maintenance questions about metal finishes, they often don't know what a finish really is these days. I realize that "piano hinges" aren't used exclusively on pianos, but if an owner rubs the chromate off the hinges on their new piano by using brass polish, who is responsible? If you used yellow chromate to try to make the hinges look like brass, I think you are. Good luck.
You can achieve brass colour with out nickel or with less nickel (like wood nickel which is plate direct on stainless steel and after the wood ni you can plate brass)
Vikas Shrama2006
publicly reply to Vikas Shrama
