Thread 398/85
Mild corrosion and stain in 7075 alloy
We have solution treated 7075 clad sheet (0.032 inch) aluminum alloy at 925 F and quenched in 22% glycol for 5 minutes. After washing and drying, it was found that most of the sheets had got blackish (light to dark) stains/corrosion. Recently we found the Na content in our water is 320 mg/l. What may be the reason and suggestion to avoid stain/corrosion? What may be the effect of Sodium?
R. K. DassAlumatherms - Stanton, California, USA
publicly reply to R. K. Dass
Common causes for staining are an unclean surface prior to heating and a contaminated furnace atmosphere. Also, for alclad 7075 sheet, the solutionizing time must be limited to avoid surface enrichment of zinc. For 0.032" sheet, the 7072 cladding is only a nominal 1.28 mils thick. ASTM B597 [withdrawn] recommends furnace 'soak' times of 15-25 minutes for salt baths or
25-35 minutes in air; shorter if the actual metal temperature can be measured, with total time above 860 F not to exceed 30 minutes. If the sheet was previously heat treated, I would limit this time much further, e.g., to 5 minutes.
Sodium (Na+) would not cause staining, but accompanying anions could. The sodium is perhaps from sodium nitrate
⇦ this on
used as a corrosion inhibitor in polyalkene glycol (PAG) solutions or hard water make-up
(use DI). At minimum, monitor the PAG for pH, conductivity (for dissolved salt, up to 1% NaCl) and biological degradation. Follow any additional supplier instructions.
Add a final hot DI water rinse (dip or spray) to avoid further staining and to aid drying.
- Goleta, California
publicly reply to Ken Vlach
