Thread 398/75
Cold Rust Bluing Problem
Hi there
We have been experimenting with using the cold rust blue recipe shown on this site May 8th 2000 by a David F Fiola from Godfrey Illinois USA (letter 982). The problem we have is that after coating with the solution and allowing to rust over night. We are not sure how much rust has been generated on the steel.
1. What color should the rust be?
We appear to end up with a darkish color after 24 hours which doesn't always look like a typical rust. Humidity is around 50% temp 30 deg C = approx. 80 F.
2. On boiling the treated steel in water for 5 min it definitely goes black and this is able to be wiped off easily ? almost too easily leaving very little bluing deposit even after 10 coating cycles.
AgResearch - New Zealand
publicly reply to Philip Budding
A. Welcome to gun blueing 101. In my experience, EVERY method of producing rust on the item leaves, RED OXIDE rust. Simple boiling in water, will turn the red oxides dark. You would not believe how long I searched for this same answer, in the days PC (pre computer)
Boil it for a few minutes, then using a fine soft wire brush, or degreased #0000 steel wool
⇦ this on
Amazon [affil links] , remove the accumulated "rust". While still hot enough to dry the next coat of solution, apply, let cure overnight, boil, repeat. Typical firearms steel, may take 5 or 6 boilings.
Cleanliness is next to godliness is the whole trick, and having a properly polished surface to start with. Most guys will stop between 400 and 600 grit polish medium.
Upon re reading this, I realize I told you most of what you have already tried, I apologize
Don't forget, when this method was used, gun steel was a lot softer than it is now. When Winchester for example started adding higher amounts of nickel, that complicated the finish process.
It appears to me, you have plenty of rust. Are you removing it by hand? Or power? If by power, you may simply be getting too heavy handed. Good luck, it's a long learning curve. Sorry for the false start I first advised. o.
cutters and collectors - Fallon, Nevada
publicly reply to Ron Ryder
A. All gun manufacturers use the hot black oxide process, and you will find it gives a more uniform and durable color. There are many shops which do black oxide coating, and it is not very expensive. This is not a reasonable process to do outside of a metal finishing shop, but the end result will be worth having it done by a pro.
publicly reply to Jeffrey Holmes, CEF
Thanks to those that have replied. A reasonable amount of trial and error have seen us eventually come up with an excellent finish.
Finished product:
Phil
