Bubbles problem on Ni-Cr plated materials
I am working in a plating company for almost 3 months now. For the short time that I have been here I have encountered so many bubbles problem on Nickel Chrome plated materials. What is/are the common reason of this problem? I would appreciate your immediate response to this inquiry.
Abigael D. Lozano
Plating - Butuan City, Philippines
Is your problem bubbles under the nickel layer or deformities in actual nickel coating?
What type of nickel are you using [Vin ordinaire dull] or a proprietary bright nickel?
Blistered nickel is usually caused by poor cleaning and adhesion is normally tested by rubbing the coating hard with the edge of a coin.
Mel Platt
Mel Platt
geriatic mel - Maidenhead, U.K.
