Stripping silicon oxide and titanium oxide coatings from aluminum
Question 1,
Any way to remove 4 plated layer in sequence of SiO2, TiO2, SiO2, TiO2 on an aluminum material 6061 without damaging the surface. Please advice.
Question 2,
Any way to remove 5 plated layer in sequence of SiO2, TiAlO, SiO2, TiAlO, SiO2 on an aluminum material 6061 without damaging the surface. Please advice.
Plating shop - Malaysia
Try concentrated hydrofluoric acid.
It should dissolve the oxides and leave the aluminum covered with a thin white film of AlF3.
- Goleta, California
