Stainless knives rusting
Q. Lately we have been having trouble with knives rusting while sitting in a sterlizer at a meatworks.
For some reason the knives are coming out with rust spots all over them. Different brands have been tested to insure it's not a bad batch from one company, some have been sharpened then placed in the sterlizers while others are new, straight out of the packet. Water temp is greater than 82deg and water pH is between 6.3 - 6.4.
Does anybody have any ideas on what may be causing this?
Fil Farina
- Bordertown SA Australia
High Quality
Activated Carbon
activated_carbon_gran
A. Perhaps some form of chlorine. Make sure that there's no bleach (hypochlorite) residue, then try using distilled or demineralized water in the sterilizer.
If this works, get your present water analyzed. Activated carbon filtration can remove chlorine, but reverse osmosis (RO) may be needed for chloride removal.
Ken Vlach [deceased]
- Goleta, California
A. The possible explanation - lack of oxygen, required for passivation, during sterilization. The suggestion is: submerge knifes in the solution consisting of 1% of baking soda [in bulk on eBay or Amazon [affil link] plus 1% of hydrogen peroxide. Then without rinsing put knifes into sterilizator.
anna_berkovich
Anna Berkovich
Russamer Lab - Pittsburgh, Pennsylvania
