How to seal on a nickel plating surface?
Hello
Our company wants to seal a resistance on a nickel plating surface, but it is hard to confirmly connect. How to deal with it?
DAVID
- Nanjing CHINA
Ed. note: Can you add a few more sentences to flesh out your inquiry? We don't understand it.
I want to know what kind of activator shall I choose to help seal on the nickel plating surface.
Wanliang Dai- Nanjing, CHINA
Please describe your situation. What do you mean by activator? Did you mean activate? What is the substrate and describe the type of plating bath and deposit. For what purpose do you want to seal? Reduce porosity, reduce thickness, time and cost? Please remember we are not there to see what you are doing.
Mr. Guillermo Marrufo,
Mr. Wanliang Dai refers to the problem faced by them in soldering some resistance to nickel plated surface.
This question is posted again as letter no. 39690.
Mr. Nick Clatworthy has made some suggestions regarding this.
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
(ed.note: The good doctor offers a fascinating blog, "Advancement in Science" )
A chromic acid dip followed by a wax coating will help seal Nickel well, if you mean you want better corrosion resistance.
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
