What is the definition of room temperature for the plating industry?
We run plating tanks at "room temperature" but with the New England winter and summer variations in temperature, is "room temperature" acceptable or do we need to define a temp. range for tanks that do not require chillers or heaters?
Lynne Nasonmetal finishing - Methuen, Massachusetts
You live in an extreme climate area, so what? Most of the time you certainly enjoy an air conditioning environment and you absolutely understand the concept. It's the same thing. What would be an acceptable temperature setting for a ROOM heater or cooler in your opinion? Do not expect a fixed value. A reasonable variation or tolerance is acceptable. Guillermo MarrufoMonterrey, NL, Mexico Hello Lynne, process engineer - Malone, New York What tanks are you running? Have you noticed a performance affect caused by the weather? Compton, California, USA Dear Lynne Nason, ![]() T.K. Mohan plating process supplier - Mumbai, India |
The issue partly revolves around semantics as everyone seems to be alluding to but not stating. There is room temperature and there is ambient temperature. Ambient temperature is whatever the actual temperature in the room happens to be (my apologies to those who realize that this is a simplification); room temperature is generally regarded by most process manufacturers to be between 68 and 72 degrees F. although it is regularly stretched to a range of 65 to 85 deg. F. when it is convenient for marketing purposes
(note: I have been developing processes, servicing plating shops and writing technical data sheets for over 30 years and the above is based upon my experience)
- Great Neck, New York
Second of two simultaneous responses -- 2006
Check with your supplier.
Room Temperature is a bit vague, and a term I have never seen used by solution manufacturers.
By suppliers yes, but not manufacturers.
Do your tanks stand on concrete?
This can lower the temperature in tanks drastically.
Are the tanks very tall?
Temperature variations in tall tanks can be quite significant.
Do you have pumps or spargers to maintain circulation and keep temperature stable?
Temperature variations affect color, plating rate, amperage requirements, drop out and consumption of brighteners and metals.
I would not buy from a supplier that did not give full specifications.
All solutions have performance parameters.
The manufacturer knows them and should supply them along with the products.
polishing and plating - Belfast, Maine
