How can I make beautiful black patination on copper?
We make decorative laminate sheets by using high temperature & pressure.
We have also aluminum foil in our range.
The sheet size is 2440 x 1220 mm. & the thickness of the foil is from 100 to 300 microns.
Now, we want to start Copper foil in our range with patination process.
So, here I have a question that how can I make Black patination on Copper?
If I make the foil embossed & there are some deep are in the sheets & I also want to make black this deep area by patination.
You are requested to give an answer as soon as possible.
- Ahmedabad, Gujarat, India
There are countless letters in the archives describing patination methods and recipes. Try the search engine using the terms "black" and "copper".
Compton, California, USA
