Arsenic Plating
Dear All
We need the best method for plating Arsenic (As+3) from solution as element. It would be appreciated any help.
Best regards,
MITPL - Perth, Australia
Ed. note: your question could probably be answered best if you described the specifics of your situation instead of casting your question in the abstract, Reza.
Arsenic plating:
100 gm arsenic acid
30 gm sodium carbonate
⇦ this on
Amazon]
(calc.)
10 gm potassium cyanide
1 lit water
charcoal anodes(in silk bags)
0,4 A/dm2
15-20 °C temp.
Very toxic stuff-avoid any contact with solution,objects must be oxide and grease free!
According to W.Machu:Metallische Ueberzuege,Leipzig 1948.
