Electroforming insects, scorpions, etc.
Q. I have a small Nickel electroforming company. We Electroform optical reflectors from stainless steel substrates. At certain times of the year, we get all kinds of bugs from scorpions and preying mantis's that die in our shop. We want to try to electroform a shell of nickel on the scorpion, rhodium plate it and see if we can sell them in knick knack stores. I have some experience with non conductive surfaces like glass and plastic, but not bugs. I was thinking of a sequence of lacquer, silver nitrate, nickel electroform, rhodium and then the store. Any suggestions?
Kelly Pichel- Aguanga, California
A. Several years ago (perhaps 8 or 10) an article in The Metal Finishing Magazine reported on the subject. Maybe you can get a reprint or a copy of that old issue from the editorial house or through this site's advertisers.
for Artisans, Jewelry, Crafts
avail from eBay, AbeBooks or Amazon
avail from Amazon
avail from Amazon
A. Dear Kelly, ![]() T.K. Mohan plating process supplier - Mumbai, India A. Refer a book ![]() Khair Shishani aircraft maintenance - Al Ain, UAE |
A. Beats plating live ones but----
PLEASE don't try this in your production tank. Scorpions may contain chemicals which will enhance your plating - but I would not want to put money on it. It is much more likely that it will have adverse effects on stress, brightness or both and cost more to rectify than your potential gain.
It is much safer to put a small quantity of solution in a separate beaker [beakers on
Amazon [affil links] with its own anode.
If you want to maintain your usual temperature, suspend the container in the tank, but don't spill the contents into the main solution.
A. I do investment casting (Lost wax) we did some bugs last year in Sterling Silver (just a couple, for fun). Procedure is a lot simpler than metallization. All I did was spray with lacquer to harden and shape the bug. Attached a wax sprue, tree, invest, burn-out and cast.
Once casted and clean, it can be replicated by making rubber molds and make wax patterns for casting metals such as brass, bronze, sterling Silver or gold.
- Mays Landing, New Jersey
A. Use the resources available, including www.finishing.com/chemicals/
Russell Richter- Danbury, Connecticut, USA
