HCL scrubber system
Hi guys, need your help!
I would like to redesign HCl scrubber system in my plant
Currently we have 6 HCl stock tanks , DI = 8m , H=10m
I would like to find a software or website that able to help me to design the above scrubber. Thanks guys....
Lee shyu yuan
Chlor Alkali Plant - Malaysia
Hi Lee,
HCl? Easy.... just now there are some systems in Alberta for scrubbing pure, unadulterated l00% concentrated HCl even at minus 25 degrees C! Efficiency? Given @ 99%. Design? Inertial 3 micron LMITS scrubber.
Getting back to your question, mine is about the given DI = 6 M. Is that 6 meters diameter?
If that is so, then the airflow will depend, I'd assume, on just what airflow are you generating during the loading of the tank. Probably, at a guess, 500 cfm... which means a fairly small scrubber.
I'd need more info, please.
freeman newton portrait
Freeman Newton [deceased]
