Reduction of lead impurities in lead-free plating solution
Dear expert,
We experience high concentration of lead (Pb) on our lead free plating solution,
I'd like to know some technique how to reduce this impurities,what process?
Can you define step by step procedure how to reduce lead impurities?
- Philippines
Your plating bath supplier may have a chemical procedure for precipitating lead from your current plating solution. In the meantime you could dummy plate the bath at 2 amps per square ft for an hour or two per day until the Pb drops to a point of tolerance. Low current density dummy plating favors deposition of minority or trace metals. Good luck!
Mark Bakerprocess engineer - Malone, New York
