Zinc removal from wastewater
Q. In my business I do acid chloride zinc I use inhibitors in my hydrochloric acid pickle. Could these inhibitors have an effect on the pH in my waste treatment system. I have seen the pH fluctuate from 10 1/2 to 7. if the inhibitors do cause a problem how can I treat them so they don't affect the pH?
Gary Follmar
- Houston, Texas
Q. We have a bathing tub of size 900' by 8' and 10' deep. It contains 1.6 mgallon of water with approximately 6 ppm zinc. Now we want to pump all water at 300 gpm and throw in the ocean, but before that we have to remove zinc. Is there any device or technique that can be used?
K. [last name deleted for privacy by Editor at request]
university - Pennsylvania
A. Hi, K. This is a very substantial volume! You want to treat and discharge as much zinc-bearing waste in a week as 10 or more large industrial zinc plating plants would discharge. And each of the ten would have at least one certified waste water treatment system operator plus a safety and environment manager.
So this is not something that can be done casually with internet forum advice, but must be carefully orchestrated and monitored. I think you should contract with an experienced treatment company to do on-site treatment, perhaps by passing the water through ion-exchange columns and hauling them off site for regeneration, but certainly not discharging at a rate of 300 GPM. Further, I didn't know that ocean dumping was even legal. Good luck!
A. Without knowing the exact makeup of the "lake" you are wanting to treat is is difficult to offer a solution.
1. Are there any complexing agents in the water?
2. 6 ppm is not that bad. Actually more is better from the treatment side of things.
I would check with the supporting vendors on this site, contract a "portable batch treatment system".
Finding a treatment system that is capable of treating 1.6 mgallon in a week is probably not going to happen. That would require a system capable of effectively treating at 158 GPM running 24 hours a day. Plan on the process taking about two to three weeks, and look for a system that is used for precipitation OR you could contract out membrane filtration, Reverse osmosis or even Ion exchange.
There are lots of companies that offer these services, just look around finishing.com here and it will lead you in the right direction.
Ryan Cook
Ryan Cook
Toccoa, Georgia
A. I agree with Ted. This is a large volume of water, and thought must be put into this as there will be cost issues to consider. Ion exchange columns will work but this may be overkill in this situation. You can flow the water through a filter type media to lower the zinc or you may just need to adjust the pH and drop out through hydroxide precipitation. Contact or consult with people in the heavy metals field (Wastewater Treatment industry).
Gordon Djani
- Greenville, South Carolina
A. Sir:
I once had this problem for a client, but do not know if he followed through or not. In Zinc Abstracts I found that passing the water through ground-up automobile tires the zinc ion was absorbed in the carbon in the automobile tires. The generated ground up automobile tires was then used on an agricultural field for available zinc ion. The crop was either corn or sugar beets. The water passing through the ground-up automobile tires had only a few tenths of a ppm still dissolved.
Dr. Thomas H. Cook
A. Fairly high levels of Zn, but you might want to check with companies like Tigg Corporation or Great Lakes Carbon. They both have mobile units for ion exchange up to 500 - 600 gpm. Forms of activated alumina have fairly high adsorption capacities for Zn (up to around 60 - 70 mg/g) and they are familiar with the process.
Activated alumina is being used for Zn removal from ballast water, and storm water run off at a couple of galvanizing yards.
William Reid
- Naperville, Illinois, USA
November 5, 2009
Q. We run a batch treatment waste stream and we have found a high level of zinc in the first stage cleaning rinse tanks. We have tried pH adjust and numerous chemicals to drop the zinc of the this waste stream with no luck, however, we are only having this problem in the chelated rinses after our cleaners. In the rinses after our zinc plating and chromating tanks we are able to drop the zinc out fairly easily.
Any insight anyone has would be greatly appreciated.
Mike Seidl
Waste Treatment Operator - Hudson, New Hampshire, USA
February 11, 2013
A. Hi Mike. How is substantial zinc getting into the rinses after the cleaners? If you are replating rejects by simply running them through your line again, stripping the zinc in the electrocleaner, you may have to change something -- like stripping the zinc in acid before re-running them so these chelated cleaners don't get so loaded with zinc.
As for treatment of chelated cleaners, the usual process is to lower the pH to the acid range, say pH 3.0, add a good bit of magnesium sulphate or calcium chloride to try to tie up the chelating agents, then raise the pH to the proper range for precipitation of the zinc (maybe 10.0).
Hopefully Dave Wichern will stop in and offer a more precise suggestion.
February 13, 2013
A. Why, thanks Ted!
Anyway, your suggestion is pretty good. The only things I'll add are; I'd try ferrous sulfate this on eBay or Amazon [affil links] addition at low pH, then bring it up to about 9.2 - 9.5. In my experience, 10 is a little high for Zn. However, what you suggested might work better. Experiment will tell.
A good way to go about this is to do a series of jar test experiments where the pH is varied from, say, 8.8 to 10.5 in 0.3 pH unit increments and see what works best. If the lowest residual is still higher than you want to see it, try adding various coagulants/co-precipitants at the optimal pH and see if that helps. If it does not, you will need to add some precipitant like sodium sulfide (my choice) or DTC.
dave wichern
Dave Wichern
February 14, 2013
A. One possibility is to use a chelate breaker. Another possible solution is to use only softened water for the cleaner and switch to a non-chelated cleaner formulation. There are cleaners that will do a fine job and still be treatable by hydroxide precipitation.
Lyle Kirman
February 14, 2013
Removal of Zinc from 140000 ppm to 3 ppm in wastewater
Q. Good afternoon
We are dealing with some problems in our current system for treating wastewater. Due to the high Zinc concentration, we are producing a huge volume of sludge at the end of the process. The treatment we use increases the pH until 6 with magnesium oxide and then, we add an organic flocculant in order to remove some iron present in the effluent. After this stage, we increase the pH until 10 with sodium hydroxide adding another organic compound to improve settling velocity of the sludge. However, the volume of sludge we produce is very huge in comparison of the amount of clean water (about three times more in the clarifier). We are looking for some options to decrease its volume and enhance the performance of the treatment plant.
Thank you for your replies.
Kind regards,
Jessica
Jessica Moná
engineer - Medellín, Colombia
August 18, 2017
A. Hi Jessica,
Do you have 14% in weight of zinc metal in solution? It is nearly 24% in weight of the hydroxide, and in volume it is nearly all of your wastewater, it will be very difficult to remove by precipitation...
Where is the wastewater from? Is it a one-time treatment or you produce this kind of waste all the time?
Regards and best of lucks!
Daniel Montañés
TEL - N FERRARIS - Cañuelas, Buenos Aires, Argentina
August 22, 2017
Q. Hi Daniel
Thanks for your reply
We are producing this kind of wastewater once per week in amounts 7 m3 average. We know the zinc concentration is huge (140 g per liter) but our process requires an ungalvanized stage. Do you believe a filter press could solve my problem? Or What methodology at low cost, Can we use to treat the wastewater?
I'm anxious to read your answer.
Thank you so much
Best Regards!
Jessica Moná [returning]
August 27, 2017
A. There are many filter options that could help, I think you should treat this in batch and pass it through a filter press when you get an even and good floc size.
If your biggest issue is Zinc, you should stop at pH 9, if you get over 10 you are redissolving some zinc, it is amphoteric and you may not get it out the water completely.
If you did things right, your filter press should give you almost clean water (pH ~ 9). You should see if further treatment is necessary, it varies from place to place, but if you don't have much organic it should be fine.
I use filter presses here in plant and they are very reliable, but there are some other type of filters. Best of lucks finding the best choice for you!
Best regards!!
Daniel Montañés
August 29, 2017
thumbs up sign  Good Morning Daniel
Thanks for your reply. We are going to make some tests in a filter press we rent. I hope the results will be fine.
Jessica Moná
September 25, 2017
Best of luck Jessica! Tell us how this worked for you so our colleagues can take this as a possible solution if they have the same problems as you :)
Saludos hermanos colombianos!
Daniel Montañés
September 27, 2017
How to treat zinc in storm water run off
Q. I am a waste water treatment operator at an industrial waste water treatment facility. We have not been able to pass our zinc test in storm water run off because of our galvanized roof. The roof houses two manufacturing buildings and it is not feasible to replace the roof with other material. We currently have storm water run off passing through sand filters but we have continually failed state mandated tests for zinc. Is there any other filters and/or process that anyone may know of to greatly reduce zinc from the run off water?
Rennell Henry
Waste water treatment operator - Torrance, California, USA
May 23, 2019
A. Hi Rennell. Running the stormwater through a sand filter does not help much because virtually all of the zinc is dissolved rather than suspended. If you google "zinc removal from roof runoff" you will find a lot of info from government agencies as well as vendors of treatment systems. As cynics note, you'll probably be regulated down to whatever analytical limits the regulatory agencies can monitor you to, and analytical equipment constantly improves, so don't waste money on anything that is even remotely marginal.
It's not easy to reliably paint galvanized metal roofs, but if I were you and I were confident that the galvanized roof was the source of the zinc, I'd suggest painting your roof white, with a paint which does not contain zinc or copper. Good luck.
And leave that sand filter in place to catch peeling paint chips because those agency rules will doubtless be causing an awful lot of paint to be applied to, and subsequently peel off of, people's roofs and run down with the storm water. (I'm not against regulation of environmental hazards, but I am opposed to ignoring the law of unintended consequences with an issue so well known and pervasive as paint peeling from galvanizing :-)
May 2019
