Karat purity vs. thickness in gold plating
Q. I WANT TO KNOW HOW MANY MICRONS IS 23 KARAT IN GOLD PLATING?
OLA CHARLESCHARLES BIJOUX TRADING,WATCHES AND JEWELRY - PRETORIA, SOUTH AFRICA
A. Hi Ola,
You are asking a question that relates apples to oranges. Micron refers to gold thickness as plated, 23k refers to gold purity plated. Simply put, you have 23 out of 24 parts of gold purity. One part is an alloy added to the plating solution to achieve a certain color and hardness. Hope this helps you.
process engineer - Malone, New York
Gold plating purity -- should lower karat cost less?
March 18, 2020Q. Hi,
I'm a custom jewelry buyer in Hanoi, Vietnam.
We're interested in Gold plated jewelry (in 14K and 18K).
I want to know when electroplated gold is in certain thickness, say 1 micon, what is the purity of gold layer?
Some plating houses inform me the 14k and 18k is just color reference and has no meaning to the purity, and the purity of both 14k and 18k gold layer would be 98.5% gold, and therefore the price of plating both 14k and 18k is the same.
Is it true?
If so, is there any way to plate with desired purity of gold? (e.g. 14k and 18k) so that the price of plating cost is different?
buyer - Hanoi, Vietnam
A. 14K is 58% gold. 18K is 64% gold, so 18K costs more than 14K. ![]() Jeffrey Holmes, CEF Spartanburg, South Carolina March 18, 2020 March 19, 2020 Q. Sorry if I made you confused. buyer - Hanoi, Vietnam |
A. Karat has nothing to do with thickness. Go back to Mr Holmes. Karat is an expression of purity, Holmes gave you the percentage. 99.5 % would be 24 Karat. and if plated to 0.0001 inch thick, in the USA, the jewelry industry would let you mark it "heavy gold electroplate". The 1/2% would be nickel or cobalt or indium and that is what makes it "hard".
