Hot dipped galvanized bracket on stainless steel pipe
Is there a problem using Hot dipped Galvanised brackets to support Stainless steel pipes?
For example: Copper and Galv do not go together
Bracket supplier - Hamilton, New Zealand
Theoretically yes but if you have a sufficiently reasonable thickness of zinc say 25 microns, I don't see why you shoulndt get past 10 years. Why not try zinc -nickel plating whilst youre about it?
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
