What is proper method for finishing Cast iron surfaces in two pack PU [pre-treated with sand blasting]
WE are based at Rajasthan[a dry weather state] in INDIA . We are producing cast iron items for ornamental purposes.[ Poles, bollards, etc.] We are at present using standard two pack PU products avialable in the market for finishing our products with spray gun. What should be the correct method so that we get a durable and proper finish ? Our method at present involves :
Thin coat of Zn-Ph primer then cutting and filling with Al.oxide paper and PU pottin. After this second coat of Zn-Ph Primer. Thin coat of paint and then if required we cut it and again spray one coat ,before final coat is applied.
SANDEEP DAKSHINI
Manufacturer of C I ornamental items. - Jaipur, Rajasthan, INDIA
Mr. Dakshini,
Are you having a quality problem? I don't find anything wrong with your application method. Do you feel that you may be taking unecessary steps that could be eliminated to save cost?
Sheldon Taylor
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
