Need alternative to cyanide stripping of gold
We presently use a Cyanide bath to strip material of gold and would like to find an alternate method which is less dangerous.
Gene Artinius- Manchester, New Hampshire
First of two simultaneous responses -- 2006
Hi Gene,
I have tried to use non-cyanide gold strippers in the past, with poor results. They had to be heated to a high temperature, and took forever to strip the gold. It was a good thing I got the chemicals in on trial basis. You may want to call some precious metal suppliers
(for electroplating), or a reputable refiner may know of a good product they currently use. Hope you find something.
process engineer - Malone, New York
Slightly acidified gold chloride as electrolytic etching solution can be used (object=anode),or aqua regia solution(if electrolytic method is not possible).
Hello Goran,
Thanks for the input.
Hi..
you may try this..
40% NaOH added with 23% sodium metabisulfite..Use ultrasonic system..The gold will be removed..
- Malaysia
November 18, 2009
