RADIATION RESISTANCE OF POLY OND COATINGS
How resistant to x-radiation is a poly ond coating?
John Barchi- Miami Lakes, Florida
John, Poly-ond coating is Electroless Nickel infused with PTFE into its matrix. This coating will exhibit the same effects to x-radiation as either of these alone. I'm not sure how PTFE stands up to x-radiation but, if it is affected the coating may lose some of its composite characteristics but maintain its Electroless Nickel coating.
Tony D'Amato- Chicopee, Massachusetts
