Control of spot plated silver
What processes can be used to pattern and control the spot plating of silver on a copper leadframe?
Roger ArbuthnotSemiconductor packaging - Phoenix, Arizona, USA
Maybe someone else understands exactly what you're asking, Roger, but you haven't used enough words for me to be confident about it. One of our guidelines is to spend more words asking the question than you expect people to spend in answering it :-)
Spot plating is usually done with a "moveable mask", a perforated rubber belt that is pressed against the strip, exposing only the area on the strip that you want to plate.
