Heating nitric acid passivation solution
Q. What are the problems that I could expect and what would I have to do in order to heat 40 percent nitric to a temperature of 140 °F?
Ed Wilt
electropolishing Company - Pennsylvania, USA
A. You will need a good quality heater intended to live in nitric acid for a reasonable time. I would suggest a derated or even a double derated heater if you can stand the loss of tank space. It costs more to start, but will last a long time relative to a straight heater.
You will need a good, well designed exhaust hood that includes a fume scrubber, preferably with a neutralization solution.
A. Ed,
There are no special problems to consider when heating a nitric acid solution. I use an immersion heater with an stainless steel element to heat a 200 gallon tank of 30% nitric to 120-140 °F. Good ventilation is necessary as well as a cover to prevent evaporation. The fumes are very corrosive. Hot acid is more dangerous than ambient temperature acid but both should be handled with great care. I would recommend a respirator, goggles ⇦ on eBay or Amazon [affil link] , shoulder length gloves, face shield ⇦ on eBay or Amazon [affil link] , goggles or acid suit. You didn't mention the volume you need to heat but the hazards increase when you have large open tanks. If you are going for a one-time deal and a relatively small volume, you will probably be ok. Any setup that will be used for an extended period would need some planning and most likely require you to employ a company that specializes in ventilation systems. Others options for small setups: immerse a smaller container in a larger one and circulate hot water around the smaller vessel, or heat the water for the solution first and then add the acid and allow the temp to fall (one shot deal though).
Joseph Lockrem
- Indianapolis, Indiana, USA
A. There are several alternatives such as teflon or exotic metal heaters that could be used. But, you could also heat it indirectly, that is through a double wall tank and hot water. Are you going to mix your nitric after it's heated? If so, you should investigate for possible exothermic reactions depending on your mixture.
Guillermo Marrufo
Monterrey, NL, Mexico
Q. Hello.
I'm looking for some help with heating my nitric passivation tanks in our NADCAP Passivation lab. I process IAW all of the industry standards (AMS, ASTM), types 2, 6, 8 and post treat w/ Sodium Dichromate. We currently use quartz heaters and controllers, aka, intelligent heaters. The problem is I keep losing heaters. We keep a keen eye on the solution levels to keep the heaters properly immersed, but still seem to either blow the thermal fuse on the heater, or it shorts out the system completely (GFI trips).
Am I using the proper heating system? Is there a better way to heat these tanks?
We've tried using industrial heating blankets too. Didn't work out to well...
I would greatly appreciate any additional insight. These heaters are expensive!
Josh Lundquist
Aerospace Industry, Production - Grand Rapids, Michigan, USA
May 14, 2013
May 21, 2013
A. Quartz heaters are a bad idea in any tank. They are expensive, easily broken and can present an electrical hazard when they do so.
Most passivation tanks I have seen are stainless steel.
A very popular solution to the heating problem is clamp on external heaters. They do not have to be chemical, or even water, resistant and are consequently cheap. They are also outside the tank, increasing working space and they can be changed without exposing the maintenance guy to chemicals.
A lid on the tank to keep it clean is good but at these concentrations and temperatures fume is not usually considered a problem. Monitor it and install fume extraction if it is necessary or save a lot of money and maintenance if it is not. Note: this applies to passivation only; electropolish and pickle tanks almost always need extraction.
adv.    industrial heating systems
