I need to know about chrome thickness checking
When doing hard chroming in ship engine piston grooves,after grinding the grooves,when checking the thickness of chrome plated not shown correctly.
Machining size and pre-grinding size to hard chroming is in correct specification and in correct dimensions, I need to plate chrome about 0.30mm thickness on the surface.
I using MEGA-CHECK chrome thickness checking instument.
After grinding to size of the groove,chrome thickness shown only 0.20mm to 0.23mm only,but actual thickness is 0.30mm.
I am used different instruments and new one also.
But the problem still persists.
What will be the problem and how can I avoid it?
Please answer it.
RAJAN.V.N.NAIR
SHIP REPAIRING,hard chroming - Singapore
Dear Mr. Rajan ,
For such heavy thickness you need to have microscope where you can see base as well as layer, which you can check on screen.
vishwas nangare
Vishwas Nangare
motorcycle accessories mfgr.
- Aurangabad, Maharashtra, India
Dear sir,
Thanks for your reply to my question, but it is not satisfied and advisable to my nature of business.
I am doing repair of ship engine piston crown. hard chroming on piston grooves both sides,size ranging from 26.00cm to 96.00cm and also very heavy in weight.only portable type measuring tools can use with this work. Anybody have idea to solve above problem?
If any portable instruments have measure correctly to the above work please specify.
thanks,
RAJAN.V.N.NAIR
