Nickel plating over Alodined aluminum
Hi
We would plate Nickel (Electroless) over aluminum machined parts. However the machining shop that we are working with coated the parts with Alodine before getting confirmation from us!
Do we still have the chance to coat our parts with Nickel?
Sertac Gurel
- Ankara, TURKEY
The Alodine chromate conversion coating should be removed by a normal pretreatment procedure for aluminum, and especially by an alkaline etch step. However, the chromate coating may make the etch less uniform and so I would test a few sample parts first to make sure that the finish is acceptable before processing all the parts.
Ron Duncan
Ron Duncan [deceased]
- LaVergne, Tennessee
It is our sad duty to note Ron's passing on Dec. 15, 2006. A brief obituary opens Episode 13 of our Podcast.
