Thread 388/23
Solutionizing and heat treatment rob aluminum's luster
We are into Aluminium products for Automobile segment. Parts are made up of AlSi alloy with silicon ranging generally 11~13%, through gravity die system and are subject to solutionising T6/T7 and heat treatment. What we observe that after solutionising and heat treatment, we loose luster on parts and parts look dull in appearance. We want to improve finish without loosing physical properties and hardness.
Pls. advise us for improving the finish.
- Punjab, INDIA
publicly reply to Mukesh Kumar
Use a vacuum furnace.
publicly reply to Guillermo Marrufo
What type furnace are you using? A direct-fired furnace should not be used for aluminum due to excessive oxidation and discoloration from the products of combustion.
For bright solutionizing with good temperature control, a nitrogen atmosphere with forced convection can be used.
- Goleta, California
publicly reply to Ken Vlach
