Corrosion on plated plastic
Our vendor is having a problem plating some plastic cosmetic parts to withstand 168 hour salt spray test. The results show discoloration (greenish color), fading, cracking & flaking. The process they are currently using is; nickel plate--copper plate--nickel plate & then another nickel plate for more binding energy and then a gunsmoke or gold color plating. They then finish with an electrophoresis treatment for UV protection. Do you have any suggestions on how we can prevent these problems?
Tim Stutzmanfishing tackle - Philadelphia, Pennsylvania, USA
A. Gunsmoke is? How is it affected by the salt spray?
Greenish or blue-green corrosion?
Nickel needs UV protection?
I'm not a POP expert, but suggest there may be high internal stresses in the plating. Also, the nickel might resist corrosion better w/o the copper and "gunsmoke."
1) Check some parts w/o the electrophoresis (acrylic or PU clearcoat?) examine under magnification, do some bend tests, corrosion test.
2) Suggest replacing the clearcoat with Incralac
⇦ this on
Amazon [affil links]
®, an acrylic lacquer containing benzotriazole, a corrosion inhibitor. Developed to protect bronze sculptury, etc.; lasts up to 13 years outdoors. A modified polysiloxane coating is also described, but maybe not yet commercially available. www.copper.org
- Goleta, California
The greenish colour is due to the nickel metal being corroded. This will in turn result in lifting of the protective films. Clearly the protective film is not doing its job, so you need to either apply a thicker coat or find one that is more resilient to your 168 hour salt spray test. You may get some help form a conversion coating, but it will not solve your problem by itself; another benefit of selecting the correct coating is that it can help in the adhesion of your lacquer. Talk with your lacquer supplier - it is their job to sell you the best available process to meet your needs; after all, you're paying for their services!
