Chromate treatment to aluminum
I am planning to use the mill finished Aluminum in roofing. I want to know the corrosion performance difference between Mill finished and Chromate treated Aluminum. Also what will be the difference between chromated Aluminum and painted aluminum?
SACHIN [last name deleted for privacy by Editor]
- MUMBAI, INDIA
Chromate treated aluminium is much more corrosion resistant.
Chromate treatment is standard pretreatment for painting. Hope it helps and good luck!
