EP Lacquer in Satin gold finish without using the satin nickel process
hi,
a customer here has a very interesting query, he has been doing satin gold finish in Electrophoretic lacquer also called dull gold (i.e., nickel+satin nickel + EPL in golden dye) but because of constant problems in the satin nickel tank + high pricing;he wants to try & avoid the satin ni process. My Question is, can we get the same finish by giving a Semi nickel finish (non glossy nickel) on the base metal & directly apply Matte EP lacquer on the brass or zinc product.
Please suggest.
MOHIT SABHARWAL
VISHAL DEALERS - ALIGARH, U.P., INDIA
Surely, you do not need the help of NASA.
Simply try it out.
Gurvin Singh
Mohali, Punjab, India
adv. saify ind youtube
