Can anodizing be used to roughen a surface to a given finish surface finish?
Q. I have a sheet of 6061-T6 .032" aluminum. The surface finish as it comes from the metal supplier is too smooth for my application and I would like to apply a surface texture of about Ra 80-100. I have contemplated shot blasting but the sheet warps really bad during that process. I am now considering anodizing the sheet.
What can I do to ensure that I get a surface finish within my desired range by anodizing? I know anodizing tends to increase the surface finish from its original finish, but I am looking to apply a specific finish and what I need to do to ensure that happens.
Also, will my sheet behave any differently when applied to heat. Part of the usage of this sheet, it will go into an oven at 350 °F and I would like to know if the sheet will warp significantly under these environmental conditions.
Derrick Hess
aerospace - Sunnyvale, California, USA
A. The safest way to apply a roughness to a plate like yours is to texture or chemically etch it. There are several texture houses in the west coast that can apply any of the several thousand different patterns available (dots, bumps, striations, splines, etc.) in almost any depth you may desire. Regarding warpage I don't think it could be a problem. In most kitchens there are hot plates for stoves and ovens that show no warpage after years exposed to direct flame.
Guillermo Marrufo
Monterrey, NL, Mexico
A. I would be against anodize as a means of achieving a controlled surface finish in that there is too much variability during pretreatment and anodizing to ensure a consistent 80-100 RA after anodize. For instance, alkaline etching vs. non-etch cleaning vs. acid etching will give varying surface condition prior to anodizing. Anodizing alone will vary given temperature, applied voltage, electrolyte temperature, etc. I would be more in favor of mechanical finish via Timesaver or brush finishing - akin to blasting but without associated bending of sheet.
milt stevenson jr.
Milt Stevenson, Jr.
Syracuse, New York
A. A finish spec of 80-100 (pretty darned tight spec for such an arbitrary measurement as Ra) should be achievable with anodizing, but it will involve either a heavy etch prior to coating, or a rough sanding (perhaps with 220 grit, or rougher, AL203 sandpaper) prior to coating. This will take a little R&D on yours, and your coaters part. You didn't mention the type of anodizing you are trying to apply, or the thickness, both of which have a bearing on the final Ra data. If I were you, I would start off sanding sample pieces to different Ra's, and send to your coater, have him process all the parts at once, and see what works, or see if tweaks need to be made. I would provide your coater with a wide range of samples, both above, and below your finished RA spec. Typically you will double the original (uncoated part) Ra on a 2 mil hardcoat, this will lessen as the coating gets thinner. However, when starting with a rough surface, the typical anodizing process tends to have the opposite effect, and can actually will smooth the surface, due to etching, and the substrate dissolving during the anodizing step. Make sure you are using a coater that has very tight quality control, if you want a repeatable process.
Marc Green
Marc Green
anodizer - Boise, Idaho
A. In addition to what Milt said, you must know that under heat the aluminum substrate expands 5 times that of the aluminum oxide on top, and cracks occur.
robert probert
probertbanner
A. Derrick
You should be able to find a supplier in the South Bay who can abrasive blast your sheet without warping it. If both sides require texturing, it will be even easier. A firm that reworks/reconditions semi-con tools will know what to do.
Willie Alexander
- Colorado Springs, Colorado
Any real-world experience with anodized components failing from thermal cycling?
Q. Does anyone have any real world experience with "cracking" of an anodize on aluminum due to thermal cycling which was the root cause of a part failure? If so, what was the application and thermal conditions?
(Some readers continue to suggest that anodizing is unsuitable for thermal applications. I do not want a general perception to develop among potential users that anodizing should not be considered for these types of applications.)
Chris Jurey, Past-President IHAA
Luke Engineering & Mfg. Co. Inc.
Wadsworth, Ohio
luke banner
A. I, too, would like to hear specifics about any failure so that we can put that concern into a real-world context instead of it just vaguely hanging over us! It is no doubt true that anodized coatings are somewhat brittle and do not expand as fast as aluminum and this could cause variations in surface roughness which the original inquirer was concerned about ... but, it addition to numerous engine parts and other hot industrial applications that I am familiar with, I will be a broken record and continue to talk about how happy I am with our Calphalon hard-anodized frying pans. They perform with remarkable reliability and absolutely no concern about just popping them down on a gas fired stove top, day after day, year after year. So if thermal cracking occurs, it's also possible that in most cases it is of no consequence.
A. To Chris Jurey:
NASA Technical Memorandum 104622, "Preventing Cracking of Anodized Coatings", August-----. Available from NASA Technical Reports Server.
Government-Industry Data Exchange Program Problem Advisory F3-P-99-02, 3 February 1999. Available from GIDEP.
Michael P. Barthelmy
- Beltsville, Maryland, USA
A. Re: high temp applications with hard anodizing: Consider racing pistons; in Top Fuel virtually all the teams run type III coated pistons.
Leonard Warren
- Murrieta, California, USA
December 17, 2010
