Stainless deck nails are rusting
I am a painter and am having trouble with stainless deck nails rusting. The nails are stainless ringshank and have been installed with a nail gun into pressure treated wood. A oil based deck stain was applied after the wood had weathered sufficiently. About 7 to 8 months later rust spots appeared around half the nail heads. We cleaned the rust off as best we could and re-stained. We even took a small wire wheel to the heads then coated them with a zinc primer but the rust keeps coming back. The homeowner pulled some of the nails out and sent them to a lab to see if they really were stainless which they were. I don,t remember what grade. This house is located on the gulf coast close to Ft. Meyers. Can you give me any ideas what is causing this and any fixes. Thank you
Mark Stuevepainter - Englewood, Florida, USA
The driver on the nail gun is hardened steel. It leaves a really thin layer or spot of steel on the head of the nail which starts the rust which will continue to spread over time in a salt air climate. - Navarre, Florida If the deck is on the Gulf, there's probably a lot of chloride in the atmosphere. Most grades of stainless will corrode in chloride environments. Try something powder coated (and don't use the cheap stuff). ![]() James Totter, CEF - Tallahassee, Florida According to the American Wood Council, suitable fastener materials for pressure-treated wood in coastal areas are 304 ('18-8') and 316 stainless. Since you've already experienced stainless corrosion, use the better, 316 grade. - Goleta, California ![]() Rest in peace, Ken. Thank you for your hard work which the finishing world, and we at finishing.com, continue to benefit from. All stainless steels will oxidize given time and a high moisture environment. The nails are most likely stainless, but of the wrong grade for your purpose, take a magnet to them and see if it sticks, if it does (most likely) you have stainless nails that are high in steel and low in chrome. I would suggest bronze or brass nails for this application as they will have surface oxidation, but will no corrode beyond the surface. Marc BanksBlacksmith - Shiloh, North Carolina Some stainless alloys resist rust better than others, the alloy is fairly important - the first suggestion would be to try an alloy that is more corrosion resistant. I would make more direct suggestions, but I don't really deal much with stainless - use the search engine on this site and you should be able to find some information that can help. Compton, California, USA |
Try Everbrite [a finishing.com supporting advertiser] coating. Hope it helps and good luck!
A. If you're curious about what causes rusty wood and how to avoid it don't worry -- you're not alone.
The basics are that rusty wood is caused by minerals in the wood reacting to low-grade metals...To avoid it simply shell out for higher quality metal!
- Austin, Texas, USA
July 10, 2019
