Electroplating of copper and silver onto aluminum
Q. I need to electroplate an aluminum plate of 0.4 mm & 0.7 mm thickness with copper on one side up to 70 microns and 120 microns of silver on the copper coating. How is it practically possible? if so, what are the procedures to be adapted.
VVN Ravi kumarpower systems - Hyderabad, AP, India
A. Hi Ravi kumar, - Toronot, ON, Canada 2005 A. Hi Ravi, ![]() Anders Sundman 4th Generation Surface Engineering Consultant - Arvika, Sweden 2005 |
Q. With reference to my question, no book nor article speaks about the thickness of the coating to that level (70 microns of copper & 120 microns of silver) is satisfactory. I could go to some electroplating people in & around Hyderabad , Where they say that beyond 25-30 microns, there is a possibility of peeling off. Is it so?
Also since plating has to be done on one side. Which material is good for masking? since it has to be de-masked after the operation for a clean surface.
A. 70 microns of copper and 120 of silver is piece of cake when you know some basic tricks. As a matter of fact copper and silver are among the metals that have been plated in higher thicknesses as they are very ductile and their deposits low in stress. Find a knowledgeable plater or hire a qualified consultant in your region.
