REPLACING CYANIDE ZINC PLATING WITH NON CYANIDE
NOWADAYS POLLUTION CONTROL IS STRICT IN ALL COUNTRIES , SO I want TO KNOW IF I CHANGE MY PRESENT CYANIDE BATH TO NON CYANIDE BATH WILL IT BE STILL PROFITABLE AND IS IT MORE ECO FRIENDLY.
TUSHAR NAGPAL
PROP. PLATING BATH - MUMBAI, INDIA
Mr Tushar Nagpal.
The Alkaline Cyanide free bath is DEFINITELY more eco friendly .
If it is run as it should with an anodic cleaning stage , a Filter and proper post treatment you will be able to save on rejects and also produce better quality work than from Cyanide zinc.
The only way of increasing profits is by improved quality. Alkaline Cyanide Free zinc bath deposits zinc more evenly than cyanide zinc over complex shapes and there is some saving on zinc anode.
Alkaline zinc runs at 3.5 volts in rack mode against 6 to 10 volts for cyanide zinc . The electricity saved is profit.
What are we waiting for Mr Nagpal ? India has some very successful Alkaline Cyanide free zinc installations in Pune. Ludhiana Chennai Mumbai, faridabad, Gurgaon, Coimbatore , Aurangabad, and Bangalore and everyone is making good money.
asif_nurie
Asif Nurie [deceased]
- New Delhi, India
ALKALINE CYNIDE FREE PROCESS IS 100% ECO FRIENDLY,ALSO MUCH ADVANTAGE OVER ACID AND CYNIDE PROCESS. MOST OF THE JOB PLATERS SWITCHED OVER TO ALKALINE CYNIDE FREE PROCESS AND FINDING MAJOR ADVANTAGE BY INCREASING HIGH VOLUME QUALITY PLATING JOB WORK.IT IS VERY SIMPLE,ECONOMICAL, HIGH QUALITY AND PROFITABLE VENTURE.
p gurumoorthi
P. Gurumoorthi
electroplating process chemicals - Chennai, Tamilnadu, India
