  Thread 382/30
Steel and Aluminum together in Salt Spray Test
Q. Is it possible that having phosphate-coated steel, and anodized aluminum panels, together in the same salt-spray chamber, could be affecting the test results? I.E. creating some sort of corrosive reaction between metals?
Ilene Weisberg
aircraft products - Ravenna, Ohio, USA
publicly reply to Ilene Weisberg
A. Only if the parts were touching.
Peter Van de Luecht
- Melbourne,Vic, Australia
publicly reply to Peter Van de Luecht
A. Given an option, I would not mix them on the same rack. In the same chamber at the same time should not be a problem.
publicly reply to James Watts
Q. We have two types of products. One is aluminum alloy, the other is steel with nickel plating. We will do the salt spray test. Can we put these two products into the same salt spray testing chamber? Thanks!
Leon Lin
- taipei,taiwan
May 4, 2018
publicly reply to Leon Lin
A. Hi Leon,
As long as your parts are not touching (would cause galvanic corrosion) and are ensuring that the salt solution that touches the parts are not being recycled for the fog solution again (another source of galvanic corrosion). The salt spray test will be valid for both parts. (Note that salt fog that does not touch the metal parts can be reused, assuming filtering, pH and salinity are checked before reusing).
Erick Leong
Vapor Bus International - Buffalo Grove, Illinois, USA
June 6, 2018
publicly reply to Erick Leong
