How to increase hardness of the electroformed sheets of nickel
I am in hologram business. I have nickel sulfamate bath to produce electroformed thin nickel sheets. I want to increase the hardness of the sheets. Any suggestions? For me the most preferable method would be playing with existing process parameters (if possible!) rather than using additives...
Moreover, I appreciate if someone gives advice about the operation of the hull cell equipment. By carrying out hull cell tests, which information can I get about how the bath contents (concentrations) effect the produced sheet, and the current density, throwing power etc....... Thank you for your replies already! :)
plating shop - UK
Moving to nickel-cobalt is probably the best way to improve the properties, including hardness.
First of three simultaneous responses --
Ted's idea will work, but it requires quite a bit more frequent lab testing until cobalt additions are down to an amp/hour science.
Another common hardener is sodium tungstannate. Requires tougher testing than cobalt and normally costs more, but can go slightly harder.
Second of three simultaneous responses -- 2005
Nickel can be given increased hardnesses by either adding up to 1g/l sodium saccharin or by using nickel-cobalt alloys. The former is susceptible to sulfur embrittlement if used at temperatures above about 160 °C and the latter is more difficult to control.
Third of three simultaneous responses --
Just to add that the tensiometer, rather than the Hull cell, is the tool of choice for electroformers. Hope you already have one and use it.
