Enamel steel test
I want to ask about if there is any speed test can be applyied on steel to detect if it will be cause a problem after enamel painting?
Mohamed Mahmoud Hanafy
enamel business - Cairo, Egypt
Dear Mohamed Mahmoud Hanafy
You ask about if there is any tests for steel before painting it by enamel.
Yes as you know there are special steel alloys suitable for enamel painting and those steel must be have aspical chemical composition and physical proparties and you must make analysis for steel and compaire it with eur standard EN 10209.
There is a very important test for steel before paint it is fish scales test and you can do it by special enamel formula to test the quality of steel.
Aly Gomaa
- Cairo, Egypt
