Zirconium Plating? Who does it?
Small stainless springs (.5 long, .20 OD, .02 wire diameter) and housing/manifold components that could use zirconium plating for formic acid resistance.
Quantities starting small (less than 200/year to start) ramping up quickly. no specifications set on thickness yet.
Will accept plated wire that could be spring formed.
electronics manufacturer - Burnaby, BC, Canada
