Wood Stove smokes from the joints
I have an old South Bend cookstove that seems to have seen better days but it still in good condition. I want to use it in my hunting cabin. How do I seal the cast iron plates that make up the top? It seems when I fire the stove it smokes from all the joints. I KNOW "JUST REPLACE IT" but it is an economic issue. I only need it to be usable. I love to spend time in my cabin so it is important to me. Any experts out there that could help? I wonder what the AMISH would do? They are the worlds best cheapskates next to me.
Gary Van Scyoc
retired - Ashland, Ohio
"Stove and
Fireplace Mortar"
stove_mortar-sealant
A. I don't know what the Amish would do, Gary, but I'd spend about $10 for a sealant made for the purpose :-)
thumbs down sign I'd be interested in an answer, too. We have a cabin with a dual-fuel South Bend stove (LP and wood) and it smokes, too. I wonder if it's a drafting/clogged flue problem. I can't believe filling it with silicone seal would be a good solution.
Jim Schmidt
- Macomb, Illinois, USA
June 15, 2009
thumbs up sign Hi Jim.
I'm not a woodstove expert, but I had a welded steel stove and now I have a cast iron one. The welded steel one was inherently airtight because everyplace where the plates met, they were continuously welded. The cast iron stove is not welded; rather each joint line is filled with a black mortar or sealant to make it airtight. I can't say that it's the exact same sealant shown in the ad, but it does seem to have some good reviews on Amazon from people who used it for that purpose.
I don't know whether you have a clogged flue or not, but I think an airtight stove needs to be sealed at the cast iron joints and unable to smoke from them regardless.
Best of luck.
