Best clear topcoat for black oxide (>100hrs salt spray)
Q. We have a request for small black oxided steel parts with good corrosion resistance.
The required finish is more cosmetic than functional and we thought of dip coating these parts in a clear, low viscosity resin just after the blackening process.
Which type of resin would be better? Epoxy, Polyurethane, Acrylic?
Any suggestions on where can I find it in the EU? My recent experience shows that importing "dangerous chemicals" from the US into Europe can be a long and tricky process...
Luis Henrique Godinho
RIREV, Lda - coating shop (PVD, WS2) - Vagos, Portugal
A. I think that you can use Paraloid B 44 acrylic resin (7,5% solution-75 gm Paraloid B 44 dissolved in 1 lit toluene )!
A. Hi Luis. I can't comment on the specific clearcoat Goran suggests, but you obviously must not wax or oil the black oxide ... and without those protectants it can flash rust in 1/2 hour or less. So your "just after" is critical. The parts need to be properly rinsed, thoroughly dried, and clearcoated immediately. Good luck!
