Metal cabinets, gravity fed spray gun
I have some metal cabinets that need to be refinished. My paint gun is powered by a compressor, is gravity fed and puts out a low-pressure spray, like that used to paint cars. What kind of paint can I buy to use?
Stan Rogers
record producer - Louisville, Kentucky, USA
Your local supplier of automotive paints can fix you up with the proper materials to do a first-class job. Just follow their advise - no short cuts.
Jeffery:
Many thanks. I bet the cabinets turn out great.
Stan James Rogers
If you want to go automotive-style and do it yourself, you might be in for a surprise at what is involved in order to get a decent paint job. I would have the job out-sourced or replace the cabinets. Save yourself a migraine.
Sheldon Taylor
Sheldon Taylor
supply chain electronics
Wake Forest, North Carolina
