Nickel-cobalt electroforming process Q&A's
adv.   nicoform
Q. I am looking for a transfer of technology and supply of equipment for electroforming. We are a mold and die manufacturer looking for implementation of this technology in our facility. We have the common state of the art manufacturing equipment but need further guidance in tool and die manufacturing particularly in this field. Any information on the matter shall be greatly appreciated. Thanks
We are a die and mold maker and wish to add nickel and copper electroform equipment for use as mold and electrode for plastic molds.
Jimmy Chan
1995
"Electroplating and Electroforming for Artists and Craftsmen"
by Jay H. Newman
electroforming_for_artists
or eBay or
A. Hi, Jimmy. NiCoForm [a finishing.com supporting advertiser] has demonstrated great ability in nickel and nickel-cobalt electroforming. You might wish to talk to them and see if they can license the information and guidance you are looking for. Good luck.
Q. Dear Sir or Madam:
Hi, I would like to producing embossing die by using High Hardness Nickel Electroforming processing, My purpose is transferring holograms on soft metal surface, like gold, silver or aluminum. The Nickel embossing die's hardness must be above HV500 with low inner strength.
Thank you very much.
Zhang Wei
Shanghai Inst.of Laser Tech. - Shanghai, China
A. Look into licensing a nickel-cobalt electroforming process; it will deliver mechanical properties that you won't be able to get out of pure nickel.
A. The simplest way is to use sodium saccharin in a nickel sulphamate bath. A stress-free deposit can be obtained with an addition of between 0.2 and 2g/l of saccharin. However, if the nickel is to be heated above 160 °C it will embrittle because of the included sulfur. To overcome this, use cobalt in place of saccharin and deposit a nickel-cobalt alloy (say 10-15% Co in the deposit).
Q. Who will be kind to tell me the process of Ni-Co electroform, including all the solution concentration?
Jack Chou
Microform tech. co ltd - China
A. Plating and electroforming nickel-cobalt alloys is not straight forward as the cobalt is depleted much faster than the nickel. The advantage is that such alloys can be heat treated and used at higher temperatures without running the risk of of sulfur embrittlement - a common complaint when hardeners such as saccharin are used. As a rule of thumb, the ratio of cobalt to nickel deposited from a given electrolyte composition does not vary significantly with pH, but it does with temperature and current density. The temperature does not have a great effect, but increasing it form say 25 &dg;C to 60 °C will result in an increase of about 15-20% in the cobalt concentration in the alloy. The biggest effect is that of current density. For instance, for a bath plating 30% cobalt at 0.2A/dm**2 may only plate 10% cobalt at 10A/dm**2. To electroform nickel-cobalt alloys you need
Cobalt depletion is quite complicated. A bath with 15% cobalt can produce a deposit with about 45% cobalt, whilst a bath with 40% cobalt will give a deposit with about 80% cobalt.
Electroforming will require continuous dosing of the electrolyte so that the bath cobalt level remains constant. You will also need to use nickel and cobalt sulphamate, as sulphates will give a much more stressed deposit. Stress relievers normally used with nickel electroforms may not work with cobalt baths, so you have to be careful about additives. The best way is to use as basic solution as possible with a minimum of additives. Luckily adding cobalt also brightens the nickel deposit.
I have never heard of anyone using S-cobalt as an anode, as you would use S-nickel in conventional sulphamate electroforming, so chemical dosing is essential. Using straight cobalt anodes will result in passivation of the cobalt and loss of control. Adding chloride will help cobalt dissolution but will also increase the stress in the alloy. As with most alloy deposition, there is always a stress problem, so it is best to minimise any possible problems.
Electroformed Nickel Cobalt alloy, heat treatment info?
37641ext
Q. Does anyone know where I could get the info for Nickel Cobalt alloy electroforming? And the specific heat treatment requirements? Any help would be great! Thank you in advance.
Michael Smith
- Quezon City, Philippines
August 18, 2017
Hi Michael. Berl Stein of NiCoForm [a finishing.com supporting advertiser], et al, wrote a paper that sounds like exactly what you're looking for :-)
August 2017
adv.   nicoform
