Low stress electroless nickel + immersion gold
Which specialist investigates about low stress electroless nickel + immersion gold process for PCB manufacturing industry?
how it effects Flex board bending OR other performance?
who can tell me more information about them?
thanks for your attention.
Ge FX
Ts - SH, CN
If your question is where to find a consultant to retain for this, Ge, our Directory of Consultants is a good place to start. If you are asking to start a public dialog on the subject, results are always better when you start the dialog by introducing yourself, your own problem, and your progress to date. Good luck.
Ge FX,
Your suppliers might help you in determining the stress in electroless nickel.
Usually they are semi bright electroless Nickels.
We are successfully plating Immersion Gold on electroless nickel for Flex boards with out any problems for years now.
Sridhar Bushigampala
- Toronto, ON, Canada
