Rust in transportation by ship
We have been sending our hand tools made of iron to Europe and USA for long time. recently we found a severe problem of rust in our products. We could not realize the cause of rust as we are putting rust preventing in all products duly painted o some surface.
I wanted to know about term container rain and its causes .
HANDTOOLS - Delhi, INDIA
Container rain is basically just as the name implies, water condensing on the roof & walls of shipping containers during long transport periods and this can drip on the products inside. The cause is high humidity, something you can't really avoid with sea transport around the equator. search google for "container rain" and you will find heaps of companies offering services such as specially built containers, dehumidifiers and desiccants to cut this off this at the source. But anyway what kind of rust prevention are you currently using? perhaps there's a problem with it?
Peter Van de Luecht- Melbourne, Vic, Australia
A. Dear sir,
I tried a product called Autosol
⇦ this on
Amazon [affil links]
which is good for the application you said, we tried this on our export enfield bullet bikes, which had this problem of rusting.
- Chennai, Tamil Nadu, India
The complete answer to your problem is Vapor Corrosion Inhibitors (VCIs). The best product for your situation might be the bags or plastic sheeting. We have a customer that had a similar problem that was solved by final rinsing in VCI cleaner then packing in crates lined with VCI plastic. The VCIs will stop corrosion for many months if done right.
Grady KnightKnight-Pro, LLC - Colville, Washington, USA
