Thread 375/71
Brass lacquers for musical instruments
I am investigating clear, possibly tinted, finishes for use on musical instruments, especially saxophones. Normally nitrocellulose or epoxy is used but they seem to lack any inherent corrosion protection for the brass - corrossion spots occur through pin-hole breaks, etc.... Incralac
⇦ this on
Amazon [affil links]
works much better at protecting the brass but lacks toughness/hardness required in this application. Any suggestions?
Non-professional instrument restorer. - Sydney, NSW, Australia
publicly reply to Martin J Porter
If you can't find other options how about: start out with a coat of the softer coating with the best corrosion protection and then finish with a coating of the harder more porous coating.
Peter Van de Luecht- Melbourne, Vic, Australia
publicly reply to Peter Van de Luecht
Try Everbrite [a finishing.com supporting advertiser] coating (probably silane based new proprietary product)! Good luck!
publicly reply to Goran Budija
