Stainless steel polishing
Dear Sir
I am working on parabolic solar collectors and planning to use stainless steel sheet (300 or 400 series/0,40 mm)as a reflector.Please let me know more about the suitable method for longlasting, Mirror like polishing.
Best regards,
Zafer Ersalan
constr.co - Turkey
We do alot of stainless with a bright finish ,I forget the U.S. finish that it is but that is not really relavent in this case. Anyway, what we do is "cut and color" our stainless on a high RPM buffing wheel that we coat with jeweler's roughe,it gives it that mirror like finish. Or another way you may be able to go is have it bright Ni(nickel) plated and then chromed (U.S.26) it you get an experienced plater they can also get that mirror like finish. Hope this helps a little bit?
Brian Gaylets
- Scranton, Pennsylvania
