Automobile Rim Finish
We are planning for Starting Automobile Rim Finishing Unit, Need information the process carried out. I appreciate your comments and suggestion.
Kumar
Versatile Metalizing Pvt Ltd - Bangalore, Karnataka, India
What do YOU mean by automobile rim finishing, Kumar; and if you are starting into this business, what are you intending to do? Are you speaking of the mechanical polishing? Or are you planning on painting rims, or maybe electroplating them, or vacuum metallizing them? Are they steel rims or aluminum alloy rims or something else? Your question, as it stands, is hopelessly broad--it's like saying you want to go into the electronics business and asking how to build electronics. Please limit your question by describing your actual situation and the questions you have in mind. Thanks! Full name in your response, please.
