Coating thickness problem
Hi,
I'm doiing sulfuric acid anodizing MIL 8625 e .
I'm performing the same parameters voltage 12-18 volts,bath conc.200g/l, temp 16-18c,
and time 35 minutes but I'm not getting the appropriate thickness, my req.is 15 micron but I'm getting only 8 micron?
can any body explain what are those parameters which can increase thickness,
thanx
precision engineering - Karachi, Pakistan
Different alloys behave differently, including requiring different voltages. What alloy are you anodizing?
Forget the 12 volts! 15 is a practical minimum and 18 is far far better.
James Watts- Navarre, Florida
For predictable results 12-15 Amps/sq.ft is even better than that! Although, on complex loads, anodizing by current density is not always feasable.
Marc Green
anodizer - Boise, Idaho
