What is the coating on aluminum cast motor/pump bodies
What is the dark coloured coating usually applied on the inner and outer surfaces of a die-cast aluminum motor or pump body? The coating is resistant to heat generated during the operation of the motor/pump.
Timur Ulucak
aluminum extrusions & finishing - Istanbul, Turkey
Sounds like hardcoat anodizing to me.
Timur
Contact the pump or motor manufacturer's tech support department and they probably can help you out.
Are you just curious, or do you have an application for a comparable coating?
Willie Alexander
- Colorado Springs, Colorado
