Centrifugal disc finishing against conventional vibratory systems
Tip: Readers want to learn from Your Situation 🙂
(little can be learned from abstract questions, so many readers skip them)
Does anybody know if the centrifugal disc finishing system completely replaces the conventional vibratory systems? What is the main purpose of this technology, rough finishing or fine finishing. Can be both reached with these kind of machines?
Thanks a lot.
plating shop - Medellín, Antioquia, Colombia
A good explanation of the differences you are looking for can be found on our website homepage of www.novafinishing.com. one does not replace the other. There are plus and minus to both systems. it depends on what you are trying to do and/or accomplish.
AF Kenton
Thank you very much.
Andres Bernal- Medellín, Antioquia, Colombia
