Epoxy to repair chrome plating tank
We have a chromium plating tank which have leakage at the joints. We want to apply some epoxy on the cracks. Can anyone introduce brands and models of epoxy which effectively works in a submerged acidic environment (or pH=2) and temperature up to 70 deg C.
Ernest LEE
Brigantine - Hong Kong
Ed. note: the banner ad above rotates to several manufacturers of tank linings and tank lining repair materials, Ernest.
Hi Ernest,
You didn't say what your chrome tank was made from, did you!
If from PVC, epoxy won't stick nor will it to polyoelefins. If metal, maybe all epoxies might stick.
Back in Ye Olden Days it was Shell's EPON 828 that would also cure under water.
Whatever you do, the epoxy will fail sooner or later ... but first of all clean the area (sand down) to be epoxied.
Go to your local supplier of polyesters and resins for help.
freeman newton portrait
Freeman Newton [deceased]
