Electroplating Copper onto Nickel Seed
Q. I am a chemist working in a micromachining facility. For some of our fabrication processes, we electroplate copper onto patterned wafers with an evaporated metal seed. Our Copper bath is an acid/copper solution with organic additives.
I am now experimenting with plating copper onto alternative seed layers. I am having a problem with peeling copper when it is plated over a nickel seed. I assume that this is because of a passive nickel oxide layer that I haven't been able to remove.
Here is my current process:
Evaporated nickel seed, high purity, ~3000 Angstroms
photoresist pattern applied
aggressive oxygen plasma photoresist de-scum process
4 minute dip into 10% HCl
DI rinse
2 minute dip into 10% H2SO4
The wafer is then placed into the plating unit with current off
Current is then applied at 8 ASD for the appropriate time to deposit ~70 microns.
If I am doing something incorrectly, or if there are steps that I should take to increase adhesion prior to plating, please let me know.
I appreciate your help.
Jon McDaniels
plating shop - Blacksburg, Virginia, USA
A. I have never plated a chip in my life, but on other things you normally would have to use a copper strike first, normally cyanide, but possibly pyrophosphate.
Q. Just to clarify, plating for my process should be very similar to other forms of copper plating. A standard method of plating onto nickel should work except that my nickel doesn't require a cleaning step, just an oxide removal.
If at all possible, I would like to avoid an alkaline step as it starts to have detrimental effects to other parts of the fabrication. I have plenty of samples for experimentation so I'm willing to try anything though.
Jon McDaniels [returning]
A. I have a couple of suggestions if you have not already tried them:
1. Try plating without the last sulfuric acid dip- the hydrochloric may be enough to clean/activate.
2. If possible, go in "hot" with current to make sure that a non-adherent immersion layer is not being formed.
Teddy McCracken
Plating Shop - Blacksburg, Virginia
A. You do not need a copper strike, you need a nickel strike - a low efficient nickel chloride (Woods) strike with 2 #/gal nickel chloride and 1 quart/gal Hydrochloric Acid and Rolled Depolarized Anodes. This will activate (remove nickel oxide) the nickel and lay down a thin fresh layer of active nickel which the subsequent copper will bond to.
robert probert
probertbanner
Q. Hello, I'm using an acid Cu bath to plate wafers with vias. I'm noticing a lighter color in the center of the wafer that also has lower via fill when compared to the edge. Is this related to a difference in current density (our electrical contact is on the outer wafer edge)?
Additionally, would having an anode with a raised center improve uniformity and center throwing power?
Justin van Staden
- Los Angeles, California, USA
August 31, 2018
